Ringing sound in converted AMV
Old 7th Feb 2007, 2:59 pm
Default Ringing sound in converted AMV
I've been trying to convert some captured TV programs. I use VirtualDub to convert them to AVI and they sound good. When I convert them to AMV, there is a ringing sound in the background. I know the AMV format has a low bitrate, is it causing this? Any way to get rid of this?
Old 7th Feb 2007, 6:38 pm
Have you tried converting it to other file formats aside from AVI before converting them to AMV?
I had the same problem once, well a little different cause I got an error message when trying to convert AVI (even if the program supports the file format) and what I did was I converted the AVI to mpeg format first and then tried to convert it to AMV and it was successful.. A little time consuming though but really worths a try! ^_^
Well I just hope this link will help you to acquire video converting programs... that is if you want to try it out!
Just click HERE
Old 9th Feb 2007, 2:00 pm
Default Re: Ringing sound in converted AMV
Thanks for the link. I actually am starting with a MPEG-2 program stream which has MPEG-2 video and MPEG-1 Layer 2 audio (according to GSpot). I've tried converting to AMV directly from this format and the audio had the same ringing sound.
Old 9th Feb 2007, 3:11 pm
majorCS, Can you do a short conversion and upload to www.uploaded.to and leave a link.
Does this happen with all amv or just the ones you convert?
What codec pack do you have installed on your PC?
Old 10th Feb 2007, 1:32 pm
My converted AMV is at http://uploaded.to/?id=7ylg4w
The original MPG file is at http://uploaded.to/?id=dtsdlc
For this conversion I converted directly from MPG to AMV using the 4.09 version.
I have the SLD Codec Pack installed. I haven't tried using any AMVs other than the ones I converted.
Old 10th Feb 2007, 2:14 pm
majorCS, What is the LCD size of your player 1.5, 1.8 or 2.0 inch?
Old 10th Feb 2007, 2:49 pm
majorCS, try this : http://uploaded.to/?id=pwnlda
Old 10th Feb 2007, 7:14 pm
tadad1, the AMV you provided plays good - no ring. What were your steps to convert it?
Old 14th Feb 2007, 8:24 am
tadad1, what codec pack did you use for the AMV you pointed me to?
Old 14th Feb 2007, 8:41 am
majorCS, The codec pack was the K-Lite mega Codec pack http://www.free-codecs.com/download_...hp?d=2879&s=42
There is some info on setting up 3.57 here:http://www.mympxplayer.org/full-scre...or--vt449.html
you can download the transformsetup.ini here: http://uploaded.to/?id=jb25w7
Just copy it into the AMVTool folder.
Splitting the converted file the_provider Video related 1 30th May 2008 7:10 pm
already-converted SMV videos noobguy Video related 1 6th Jul 2007 6:14 am
1 channel sound when converted in AMV lightoflife Video related 0 6th Dec 2006 8:09 am
How Can I Add Videos Once Ive Converted Them? KinGoFThaCiTy718 Support and How To 1 27th Nov 2006 10:43 am
(Solved) DVD .vob files ?-Can these be converted to amv ? Simonski Video related 5 28th Jun 2006 6:27 am
