AMV Volume issues
Old 21st Feb 2007, 6:59 pm
Default AMV Volume issues
I downloaded Tadad1's video converter about a month ago. At that point, I spent the better part of a saturday overwriting my rather usless AVI files into AMV... It was a mistake to overwrite, as I found as soon as I got on the bus for my daily 45 minute ride to work..(chicago public transit. 7 miles = 45 minutes.)
So now I have AMV files, about 50 of them, that are sub par in terms of volume. Does anyone else have this problem, and more to the point, is there any solution that is cheap or free in terms of software? Am I screwed on all the files already converted, or is there an existing AMV editor that I can boost the sound with?
Any answers out there?
Old 22nd Feb 2007, 7:04 pm
MPx-a-lolics Anonymous
here is a guide by tadad to improve your amvs.
http://www.mympxplayer.org/using-vir...ons-vt805.html
after you have set the audio to full processing mode as per the guide, go to audio, then to volume and tick the box. then increase the volume to about 140-200%
then convert that avi file to amv
another thing is to note the fps of your avi.
if it is 25fps, use high/low fps setting in amv converter.
if it is 29fps, use medium.
avoid using high image quality setting in amv converter to prevent format errors
thats all. hope it helps
Old 22nd Feb 2007, 8:49 pm
Default Re: AMV Volume issues
Cool! that takes care of future AVI's... but does this mean that I can't alter files already converted to AMV? that's the kicker- i would have to find them all over again...
Old 23rd Feb 2007, 8:17 pm
sorry but you cant alter the volume of the files already converted to amv
but hope your videos will look and sound better now
Old 23rd Feb 2007, 8:39 pm
Your only real option at this point, is earphones. Specifically, noise cancelling earphones, or the ones with silicone (or foam) buds that go deep in the ear canal and effectively block out noise. Especially if they are sensitive; ie. 32ohms. They can be found for a few bucks.
Old 23rd Feb 2007, 11:38 pm
either that or a mini amp.. like the ones used for personal guitar practice.. I already have a $200 set of studio headphones. end even at their peak, I it is weak. The volume isn't going from 10 to 6, it's going from 10 to 2.
Amv video volume too low.... avi Video related 12 14th Mar 2008 6:13 pm
Volume down = volume up? Opirian Support and How To 1 3rd Jan 2008 9:06 am
Hiss and low volume. mallen Support and How To 5 13th Mar 2007 9:21 am
Cannot turn the volume up phpeters87 General Discussion 4 10th Feb 2007 1:03 am
volume??! jaidagr8st Support and How To 1 26th Jan 2007 2:57 am
