Problems converting above 160x120
Hi guys. Noob in the world of mpx players. Give me a psp and I can mess around, downgrade, upgrade and wotever else needs to be done but I'm havin some trouble with mp4.
I have mp3 player utilities 4.09 and cant get a decent conversion above 160x120 resolution. At this resolution, videos play super smooth, but as soon as I go up any higher, the video becomes really jumpy, even when playing it back on my PC. I have a 2 inch player and 160x120 has a huge border round it when playing. Is there anything I could do to convert a smooth video even at 176x144? Any help would be appreciated. I have looked through the forums and can't find any posts with my specific problem. Thanks Guys A grateful noob! |
Do you mean you would like to increase its fps?
There is a tutorial about changing video size and fps for any you want to. If that's what you want, browse a little and I'm sure you will find it. Otherwise, PM me. |
Re: Problems converting above 160x120
Hi Chic. Thanks for the reply. That tool is really good but I lose some of the picture as my player is rotated 90 degrees. I can live with that tho. The instruction avi files arent the best but I think I managed to follow them ok. Do you know if theres any way to save the settings? I dont know if its worth having to configure the tool every time I want to convert a video. If there is a way to save the settings can someone please let me know. I would also love to be able to convert at even almost full screen if i can figure out a way to rotate the video. You cant do that with the required amv converter.
As I said before. I am most grateful for any help. Thanks again Metal |
| All times are GMT -7. The time now is 10:02 am. |
