Problems with MP3 Player Utilities 3.57, 3.68 & 4.0
Old 11th Apr 2007, 6:35 am
Default Re: Problems with MP3 Player Utilities 3.57, 3.68 & 4.0
Hi, when I dowload file, should I open or save it? Sorry, I really need Zip Files for Dummies!
Old 11th Apr 2007, 7:05 am
oh ok... Just save it in My Documents, then open My Documents and find the file, then follow the steps i outlined
Edit: when you get to the "Unzip wizard" and it asks for a destination directory to unzip it to, just leave it. It should unzip it to a folder called AMVconverter_4_mod or something similar
[hr:43af44b395]
Old 11th Apr 2007, 7:52 am
Okay, I will try that. I will let you know how it went later today. I must go out until about 4 pm, so I will try it then.
Thanks!
Old 11th Apr 2007, 2:44 pm
Hi _Odyssey, I followed all your instructions and I got the file downloaded and unzipped no problem. I tried to convert a movie that is over 90 minutes and the same thing happened as before. I got "Disk Full" at 81% and the converter stopped.
The movie is still not centered and the right hand side is cut off. Am I supposed to compress the AVI file before converting?
Any suggestions?
Old 17th Apr 2007, 11:17 am
Hello.. any help at all?
  #16 (permalink)
Old 22nd Apr 2007, 11:49 pm
it cannot be done anymore.............
  #17 (permalink)
Old 24th Apr 2007, 5:48 am
Hi Kei9, what cannnot be done anymore??
  #18 (permalink)
Old 24th Apr 2007, 7:37 am
ur using the version 4 right? then u might have to reinstall in ur add or remove programs in ur control panel....it might work.just stick on the procedures.
  #19 (permalink)
Old 24th Apr 2007, 7:40 am
same thing to be done with the other converters......good luck!=)
MP3 Player Utilities Problems welshbhoy Support and How To 0 26th Jan 2008 12:35 pm
MP3 Player Utilities 3.11, 3.8 or 4.11 Nonie Support and How To 2 9th Apr 2007 12:03 am
Problems installing/uninstalling Mp3 Utilities 4.03 omega1 Support and How To 6 26th Dec 2006 4:12 pm
MP3 Player Utilities 4.05 veggen Video related 4 21st Sep 2006 3:28 am
Problems with Mp3 Player Utilities 3.68 elDiablo Support and How To 3 8th Aug 2006 7:03 am
