No sound after AMV convert
Old 28th Jun 2007, 12:37 pm
Default No sound after AMV convert
I can sucessfully transcode video files to AMV on my home PC, but on a PC at work (that has no sound card fitted) using the same techniques the AMV file has no sound.
Any help apreciated.
Paul.
Old 28th Jun 2007, 12:54 pm
Default Re: No sound after AMV convert
Try install the K-Lite Mega Codec Pack from here on your work PC and see if that helps.
It might just be there isn't a codec installed on your work PC that can decode the sound into the .amv file.
Using 3.68 convert tool to convert to AMV abombaci Video related 1 27th May 2009 1:41 am
[SOLVED] AMV Convert Tool doesn't convert avionik99 Support and How To 2 20th Nov 2006 9:30 am
No Sound on my MP4 when I convert a video. _Syn Video related 13 13th Oct 2006 6:33 pm
AMV Convert will not convert files, crashes Kosh Video related 5 13th Jun 2006 9:00 am
AMV sound antdroide Video related 2 11th Jun 2006 2:55 am
