FLV to AMV, mirrored vids help
Old 12th Jul 2007, 11:40 am
Default FLV to AMV, mirrored vids help
wanted to convert flv to amv,i downloaded (as said in the FAQS here) a total vid converter that has flv.ax, first it gives a convert its original outcome and decided to rotate it to the left using 120x96,
however the other day i converted a flv file and it mirrored in the preview, and the outcome a rotated and mirrored video.
pls help me to change it back the way it used to me or is their any other way ?? pls tell thx in advance
Old 15th Jul 2007, 10:45 am
maybe download avi converter 4.0 from the download section and then convert the file to avi and then to amv?
gav
Old 25th Feb 2008, 4:53 am
try byressence amv converter http://www.bytessence.com/bamvc.html
this soft can convert lfv to amv
DOWNLOAD AMV AVI Video witch all resolution to MP4 Player
http://www.s1mp3.info/
Tools Programs Converters Editors for MP4 Playeres 8)
http://www.mpxplayer.pl/pafiledbm/
Help! Cannot get vids to play mrtfool Support and How To 3 21st Oct 2007 4:52 am
AMV converts mirrored shadow67 Video related 4 2nd May 2007 11:02 am
can you download vids. from youtube onto a chiPOD kwimbo Video related 14 26th Feb 2007 11:21 am
My mp3/mp4 player taken apart (vids) TruXter General Discussion 7 7th Feb 2007 6:48 pm
Video Error, cant covert vids mumihp Video related 3 20th Jan 2007 8:48 pm
