Audio filters (FIR / Noise reduction) for Mencoder ...?
Old 3rd Sep 2007, 7:08 am
Default Audio filters (FIR / Noise reduction) for Mencoder ...?
I need some kind of Noise reduction / FIR filter for Mencoder; is there any?
It has to be for (commandline) Mencoder, because no other software I've tried is able to produce AVI files that play in my new MP4 player (it needs a specific configuration: 22 fps, XviD, MP2 audio, and some other things).
And I need that filter because I bump up the volume of my converted files, since I'll end up watching those movies in a crowded bus, on my way to work (and maxing out the volume produces a lot of noise).
With my old MP4 player (which only played "AMV" files), I used to apply ffdshow filters (including FIR) on-the-fly, while converting, since the conversion software used DirectShow. But Mencoder doesn't seem to have anything like that filter.
I read that it can use LADSPA filters, but I don't know of any that does what I need, and I guess it would be hard to configure anyway. So I'm pretty much depending on you guys.
Greetings and thanks in advance.
Lisong 1,8 Ipodstyle Reduction of memory AR64SH Firmware 0 23rd Apr 2009 5:36 pm
MEncoder frontend for Rock Chip Avi conversion alrakis Video related 6 21st Mar 2009 12:39 pm
AVIConverter MEncoder settings spheric Video related 6 18th Aug 2008 4:33 am
BatMan - batch processing for MEncoder BobbyQ Video related 39 28th Feb 2008 6:36 am
MP4 Background Noise Darklink Support and How To 5 31st Aug 2007 10:36 pm
