Problems with amv-converter and player
Old 28th Sep 2007, 9:37 am
Default Problems with amv-converter and player
Hello,
I have a noname mp4 player from China with 1,8" Display.
The amv-file installed for demo playes properly.
I have installed MP3 Player Utilities 3.68 + 4.15.
The demo-file from the player I can play properly with 3.68 on the PC.
The properties are 16, 160x120,22050,1channel
With 4.15 the player only shows "HELLO".
I tried to convert myself. After converting I can play the file on the PC. If I copy now the same file to the player, I can't play the file from there.
If I try to play the file with the player, it shows wrong format.
Can you please help me?
Old 28th Sep 2007, 10:03 am
Meinolf2 , for 1.8" screen players, use MP3 Utilities v3.57 or v4.0 instead to encode your videos to .AMV format.
3.57 here http://www.mympxplayer.org/amv-conve...63-mb-df1.html
4.0 here http://www.mympxplayer.org/amv-conve...-mb-df118.html
See if this solves the video playback problem.
Old 30th Sep 2007, 3:21 am
Default Re: Problems with amv-converter and player
Hello,
thank you for answering!
I tried 3.57, 3.68, 4.0 and 4.15
I think, it's allways the same:
The converting runs propperly, I can play the result with the player on the PC, but after copying the file to the mp4-Player, it doesn't work. Neither on the mp4-player, nor on the PC.
I Think the problem depends on copying or file-system in the player.
What goes wrong?
Old 30th Sep 2007, 3:54 am
Meinolf2 , do you mean that at first at plays properly on your computer, then when you transfer it to the player and then back to the computer again, it does not play?
Try a format with MP3 Utilities Disk Tools, guide here http://www.mympxplayer.org/how-to-re...ck-vt2400.html
AVI Converter problems Buzzygirl Video related 13 26th Sep 2007 5:47 pm
avi converter problems for rockchip player gmaster Video related 2 7th Jan 2007 1:09 pm
AMV Converter 4.03 problems avvalex Video related 1 19th Jul 2006 3:46 am
[solved] STILL CONVERTER PROBLEMS!!!! PHIL Video related 3 13th Jul 2006 9:47 am
[solved] Problems with MTV Converter lightzout Support and How To 13 4th Jun 2006 12:47 pm
