Converting and Splitting + increasing Sound
Old 27th Nov 2007, 11:19 am
Default Converting and Splitting + increasing Sound
i want to split the movies and increase the orignal sound while converting it to MP4 or AVI..
I have win avi Ipod converter which splits and converts but doesnot increases the sound
is there any software that can do all ?? :roll:
Old 28th Nov 2007, 6:35 pm
afzal , you might want to try VirtualDub here http://www.mympxplayer.org/using-vir...ons-vt805.html
There are many settings and there should be a volume setting that you can adjust. For splitting, i'm not very sure, you'll need to play around with the software.
Old 7th Dec 2007, 9:14 pm
Default Re: Converting and Splitting + increasing Sound
You can even try the cowon and the revver sites, If you dont able increase the music through this one. :twisted:
Please visit my blog on
MP4 Music
Old 8th Dec 2007, 7:06 am
Hi, I've used Virtual Dub to split movies. It works pretty well and is easy to do.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
(Partially fixed) Converting AVI to AMV, no sound/lous static noise UnknownStory Video related 2 25th Oct 2009 12:57 am
Splitting the converted file the_provider Video related 1 30th May 2008 7:10 pm
Converting to AMV and some has no sound arucart Video related 3 21st Aug 2007 7:05 am
converting from avi to amv, lose video but sound is ok Willias Video related 3 30th Mar 2007 6:28 am
Sound becomes low and weak when converting vob to amv. Kapusiini Video related 5 3rd Sep 2006 8:39 am
