Problem trying to convert DVD to AMV
Old 18th Dec 2007, 3:48 am
eee eee is offline
Default Problem trying to convert DVD to AMV
hi all first of all
this is the first time writing on this forum i have a problem im trying to convert dvd to amv i tried it with the amv converter version 4.00 the picture is ok but sometimes the sound and the words dont go along with the picture i hope i explained properly
Old 26th Dec 2007, 1:01 am
Have a look at this thread here: http://www.mympxplayer.org/viewtopic.php?p=414.
It should be of help to you in converting DVD to AMV.
Hope that helps.
AMV Convert problem [Solved] amadeus Support and How To 3 14th Sep 2006 11:37 pm
Convert a dvd problem vcllvc Video related 2 14th Sep 2006 3:46 am
convert DVD problem using 4.03 vcllvc Support and How To 2 2nd Aug 2006 4:24 am
[solved] Problem with AMV convertor - can't convert files Tina Video related 5 1st Jul 2006 9:09 am
AMV Convert will not convert files, crashes Kosh Video related 5 13th Jun 2006 9:00 am
