[SOLVED] Another problem with Rockchip & avi's
Hey all,
Received my 1gb Stage Flash MP4 player today : http://www.ebuyer.com/product/132908 Now I know the description says it plays MTV / AMV files but it doesn't , only avi's. Problem is that, apart from the sample avi that I deleted before taking note of its compression settings, it won't play any others no matter which convertor I use. Spent the past 3-4 hours using various versions of AVIConvertor, including the one that rotates the avi by -90 degrees ( got it here in the download section - http://www.mympxplayer.org/aviconver...tup-df726.html - as the links in the forum threads are dead ), viDrop v0.55, WinAVI Convertor, all with no joy. In Device Manager it's shown as RockChip USB SD & RockChip USB MP3, and has the exact same interface as the top player in this pic : http://www.mympxplayer.org/rockchip-...rs-asp396.html And these 2, except I have a 2" display rather than 2.4" : http://www.mympxplayer.org/album_sho...php?pic_id=455 http://www.mympxplayer.org/album_sho...php?pic_id=457 If I check the players system settings, it shows the version as 00.00.0007, with a date of 2007-09-21 Anyone happen to have the same / similar player and know what program to use to get avi's working properly please ? It's driving me nuts :oops: Thanks in advance. |
How you solved this problem, MoodyBlues?
I have the same player http://www.mympxplayer.org/rockchip-...rs-asp396.html (second one), I tryed AVI Convertor, Xilsoft, viDrop Code:
(resolution 224x176 |
| All times are GMT -7. The time now is 7:31 pm. |
