[solved] Video Format Is Not Valid !! ^^^ Help !!
Old 7th Aug 2008, 11:44 pm
Default [solved] Video Format Is Not Valid !! ^^^ Help !!
Please help with my mp4 I can not see the videos ..
good format that is recognized. avi but when I get a pongo
"" Warning file format ""
mp4 is my brand AIGO F-569
and says it supports MPEG4 (AVI) would like to know how to put the videos or any program
Old 8th Aug 2008, 3:39 am
I think this is just another RockChip-Player with RK2606A- or RK2608A-Chip. The RK2606A is playing only xvid-coded avi-files with 224x176 pixels (in some cases the firmware could limited it to 220x176). The RK2608A is playing only these kind of avis with 320x240 Pixel. A 2 inch screen got typically 224 (or 220) x 176 Pixel. A 2.4 inch or 2.8 inch screen got typically 320x240 pixel.
The original converter for these Rockchipplayers is AVIConverter - mostly bad programmed and availabe in many different versions. Choosing the right one ist like seeking the needle ...
You will get faster success with the freeware viDrop, which is downloadable here at "Downloads/Tools". Download the "50 presets 4 viDrop" too and extract them into the presets-folder of the installed viDrop (after installing viDrop).
Try to use the "Generic Rockchip 320x240 high.ini"-preset or the "Generic Rockchip 224x176 high.ini"-preset and convert a very small video, upload it to your player and pray that he will play ...
Old 8th Aug 2008, 8:31 pm
WAO .. muchisimas gracias .. ! master! Now thanks if my videitos could lead to my university thank you very much ..!!!!!
[solved] Please help with unknown mp4 player video format UnknownCloud Video related 2 22nd Jan 2010 8:41 am
[solved] Rockchip mp4 - "file format error" on AVI video files haruya Video related 6 5th Dec 2009 6:51 am
[solved] Video --) file format error unicum95 Video related 16 1st Sep 2009 7:09 am
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
[solved] SigmaTel - which video format my player supports? whatsup20 Video related 4 26th Nov 2006 11:35 pm
