-   -   Help with avi to asf conversion (http://mympx.org/forum/video-related/42233-help-avi-asf-conversion.html)
makd511 25th Sep 2008 3:12 am
this is odd
there are a bunch of sample here in your screen size can you try them
http://www.mympxplayer.org/large-dc23.html
cheers
kimig1 25th Sep 2008 3:52 am
Re: Help with avi to asf conversion
Downloaded the frog - started up in Windows Media Player. Then used WMP to synch to player - still same prob....screen text flipped backwards and siad file format error. should I be using vidrop on it? And if so, how do I stop it from going into WMP?
makd511 25th Sep 2008 4:19 am
dont use media player to sync at all
use file explorer and just drag and drop files over to the player, the player qill have its own drive letter, locate the file you downloaded and drag and drop it in the players drive
no syncing needed
