Help with avi to asf conversion
Old 25th Sep 2008, 3:12 am
this is odd
there are a bunch of sample here in your screen size can you try them
http://www.mympxplayer.org/large-dc23.html
cheers
Old 25th Sep 2008, 3:52 am
Default Re: Help with avi to asf conversion
Downloaded the frog - started up in Windows Media Player. Then used WMP to synch to player - still same prob....screen text flipped backwards and siad file format error. should I be using vidrop on it? And if so, how do I stop it from going into WMP?
Old 25th Sep 2008, 4:19 am
dont use media player to sync at all
use file explorer and just drag and drop files over to the player, the player qill have its own drive letter, locate the file you downloaded and drag and drop it in the players drive
no syncing needed
AMV conversion prob razvan252 Video related 9 17th Sep 2007 5:25 am
Torrent Conversion to AMV mila Video related 2 22nd Mar 2007 3:39 pm
AMV Conversion Help minto1959 Video related 5 12th Feb 2007 6:22 pm
Any AMV conversion software for the MAC? indikit Support and How To 2 23rd Dec 2006 9:39 am
