[solved] Problem loading movies on to 2.8" touchscreen
Old 19th Dec 2008, 12:36 am
Default [solved] Problem loading movies on to 2.8" touchscreen
I am experiencing a problem loading video on to my mp4 player.
A picture of the player is here:
http://www.mympxplayer.org/album_sho...php?pic_id=654
I have tried using
amv convert tool which came with the player, and I have also attempted to use the amv convert tool which was included with the player also. I have been able to get the amv file on the player, but when I try to click on it I get nothing, when I tried to drag and drop the avi file directly in to player from my computer, it went on ok, but when I tried to play it, I got an error message saying invalid format. Any thought/recommendations would be greatly appreciated.
Old 19th Dec 2008, 3:29 am
You have linked to an RockChip-MP4-Player: these kind of players are using the program AVIConverter to convert videos into the right format: xvid-coded avi-files.
The resolution should be 320x240 pixel, the framerate maybe 20fps or 24fps.
You should better give viDrop a try, because its much better then any AVIConverter. Download it here from Downloads/Tools. Install it and use the pregiven Preset "Generic Rockchip 320x240 high.ini" inside of viDrop - this should work for this kind of players.
Old 25th Dec 2008, 7:16 am
Default Re: Problem loading movies on to 2.8" touchscreen mp4
I apologize for the delayed response, this has fixed my issue! Thanks for the helpful info, and the program.
My MP4 player stuck on "loading" blue screen kichnaz Dead Players 2 28th Jan 2011 1:33 am
"File not exist" when trying to play MP3's on 16GB touchscreen Anyka player aydinfatih Dead Players 2 7th Nov 2009 9:09 am
[solved] Problems loading movies bazross1969 Video related 3 9th Dec 2008 4:12 am
When I play AMV movies [Solved] black_sheep Support and How To 3 14th Sep 2006 3:43 am
"Format Error" while playing AMV Movies jasstone Support and How To 5 2nd Aug 2006 10:18 pm
