[solved] AviConverter does nothing on conversion
Old 27th Dec 2008, 8:18 am
Default [solved] AviConverter does nothing on conversion
Hello!
I bought an MP4-player, and it's CD contained Aviconverter 3.0. I tried all the versions, but when I click on "start converting" (or something like that), the program does nothing. I tried even vista compatible version and the result was the same. Please give me an advise, what to do, or recommend an other program! I have a 2.4" rockchip player.
Old 27th Dec 2008, 9:08 am
Default Re: AviConverter problem
Hi,
There's two free conversion programs that I know of; both are quite good:
1. www.vidrop.com
2. www.erightsoftware.com
I've used both of them and have had great results.
viDrop will even convert unprotected DVDs for you.
Cheers,
Fred
Old 29th Dec 2008, 1:03 pm
Vidrop works! Thank you very much!
Old 30th Dec 2008, 1:08 am
Thanks for letting us know Gore.
Can you tell us what settings you used that worked for your player?
[solved] AMV to MP4 Conversion tool gladson1976 Video related 0 20th Dec 2007 3:35 am
[solved] I have Aviconverter v4 in English - can't upload harry hotfoot Video related 2 29th Jun 2007 6:44 am
[solved] ME2 Player dvd conversion Martin Video related 28 15th May 2007 3:18 am
[solved] AMV conversion prasanna Video related 30 26th Jun 2006 1:32 am
[solved] Installing the Conversion Tools steffan Support and How To 4 29th Mar 2006 12:15 am
