MP4 player no audio problem
Old 5th Dec 2009, 10:32 am
Default MP4 player no audio problem
We have been sourcing some mp4 players, and have had problems with them regarding no audio on video files.
These are 4gb ipod clones with a 30 pin dock, and they use sigma_en.exe conversion software which is loaded
on the player.
The sample size was 160x120 and we succesfully converted 1 file of cow and chicken as a test, which worked.
But 2 more different files have ended up converted with no audio attached, no audio will even play in mpc
on windows. One of these files started as an .flv was then converted to avi, then converted again using the
sigma_en.exe software to be playable on the player. The other file started as an .avi file then converted
through the sigma_en.exe software but yet again no audio, even in mpc on windows.
Checking the properites on the files while they are loaded on media player classic shows the following:
Cow and Chicken (Video and Audio fine)
Video: MJPG 128x160 25.00fps [Stream 00]
Audio: MPEG Audio Layer 3 44100Hz mono 128Kbps [Stream 01]
Oasis test file the .flv one (Video ok / No Audio)
Video: MJPG 128x160 16.00fps [Video 0]
Black eyed peas test originally a .avi (Video ok / No Audio)
Any help as to what is going wrong, would be much appreciated, as I have just got to the point of head scratching.
Old 7th Dec 2009, 2:06 am
Try using this tool here: viDrop - free open-source converter for RockChip players
See if that works better for you as a lot of members have had success with viDrop in converting their videos to .AVI format which can be played on their player.
Video/Audio Synch Problem LG FM37 Aussieadam Video related 0 5th Oct 2008 8:27 pm
Problem with MP2-Audio-codec: no sound (viDrop.55) lca77 Video related 1 20th Jul 2008 2:28 am
[solved] Audio/video syncrhonization problem with Onda VX858 Matteo Video related 2 26th Mar 2008 11:13 am
audio problem NoInOi Support and How To 1 13th Sep 2006 11:55 pm
1.8 Video Problem: Audio is too fast nabilash Video related 0 3rd Sep 2006 1:19 pm
